2.7 CIS system on a 3.0
Guys, would this work? Are there significant differences between the 2.7 CIS systems and the 3.0 CIS? What about different years of 3.0- the ignition & ports were changed after '79, right?
Thanks, David |
It should work, but I've seen one attempt where the engine never quite run right...
-Wayne |
Atleast the diameter of the intake runners are different. I think you shouldn be very careful if you use the 2.7 CIS in 3.0 engine. It could be good idea compare all the parts numbers and see which are the same and which are not the same parts. Sorry I can not help more.....
| All times are GMT -8. The time now is 12:43 AM. |
