The "Best" Clutch Packages
My 2.0L race engine will be in need of a clutch and pressure plate
I have had great luck w the Centerforce package. I'm willing to try something else if someone can convince me that their is something better out there. We are not talking about alot of power, maybe 190-195 RWHP. Any lightweight pressure plates available? Let the opinions begin!!
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
Navin Johnson
Tilton 2 plate pp with a wevo, or rennsportsystems flywheel..
actually a 1 plate probably would work if you winch the car into the trailer.... oh the small tilton..5 1/4"?
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Navin Johnson
oops its 5.5"
will they work w a 901 Transaxle w a push style setup?
Navin Johnson
Yes
Navin Johnson
forgot to mention you need to massage the t/o bearing
Also figure $3000+ plus for the package
$3,000.00????????????? too much think i'll stick w the centerforce package
No Expert
Patrick sells both the CenterForce clutch and a nice lightweight flywheel for a 215mm 901 trans. I don't have the quote with me, but I remember it being in the $800 range for the clutch package and flywheel. They claim it's good to about 300 hp (I know it should be torque not HP). I couldn't find these parts on Pelican, but hopefully I just missed it. I was planning on using this on my ~240 HP 2.8 in my '69. The stock clutch is just not cutting it.
Good luck, JP
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
I hear good things about Kennedy: http://www.kennedyeng.com/
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
No Expert
Wayne,
Does Pelican carry any 901 Centerforce clutch kits? CenterForce 901 clutch kit DF191198 CenterForce 2.0 911S clutch kit DF173173 They don't show up in the search engine. How about a lightweight 901 215MM flywheel? Thanks, JP
Mark,
Call Frank... What is wrong with SACHS CLutches??
Mark Scott Vintage 911 Racer 1967 911S 2.4L ROCKET Powered by Faragallah! www.scottassociatesracing.com |
No Expert
As far as I know, Sachs does not make a beefier clutch for the 215mm 901 flywheel, just the stock one. Do anyone know the torque spec for the stock Sachs clutch package? Considering the highest HP engine available on the 215MM flywheel was 160 HP, I doubt it was all that high.
JP
Does frank have my header system done?? Otherwise Sachs are we we use on street cars!!!!!!
I have a sachs in my car. Never had a problem with it in 3 years. You saw it at willow Mark when we changed the transmission. You said it looked new... that was after 3 seasons.
I measured my centerforce w the recent engine, no wear 100 Hours+
No Expert
My stock 215mm Sachs clutch was bullet-proof with my 2.2 E engine, but when I drop my 2.8RS in, it was overwhelmed. The clutch will break loose at-will at 5K RPM at WOT. The cluch has less than 3000 miles on it with very little wear, and is correctly adjusted. I only have this one data point, but I think anything over ~200 ft-lbs may require more than the stock Sacks clutch.
JP
Location: member Central PA Region PCA , Home of the Hershey Swap
I put a Centerforce in my 3.2 in Nov. after putting one in my Talon AWD/TSI a few years ago. I like them alot. The Porsche Centerfgorce is inreality a Sachs that CF rebuilds. Talk to Patrick Motorsports. Regards,
Steve Frequent Pelican Customer 1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more 2002 996 TT X50 (H&R Springs) 2002 WRX in WRX Blue Proud Rennlist Charter Member Support and Join Rennlist.com An Expert on absolutely nothin' more than my own opinions! 2002 WRX in WRX Blue |
