Bird. It's the word...
Fishcop's Avatar
Fitting Carerra Tensioners on Early Car....Help?
Hi Guys
Getting to my carrera tensioners and I've realised that I need the part that allows the kit to be fitted to older engines... I have the oil sender at the rear of the engine. I'm assuming I use some sort of sleeve in place of the sender block from later cars, is this right?
Does anyone have a part number or a photo to help me out?
Cheers
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 06-26-2004, 06:19 PM
Order the threaded plug (900.219.009.30) and use it in place of the oil pressure sender. Jim
Old 06-26-2004, 08:20 PM
Block with plug installed on a 1973.5 T (oil pressure sender is in front of engine). Jim
Old 06-26-2004, 08:31 PM
Same engine showing more of the PS chain case and oil lines; plug is not in the block in this image. Jim
Old 06-26-2004, 08:47 PM
No Expert
jgparker's Avatar
Pelican sells an extra long oil line for Non-CIS engines so that you don't have to use that ugly bock or adapter... and it's cheap as dirt. It is Pelican part number: H-107-348-XX. I have one on my engine, and I think it looks much cleaner.
http://www.pelicanparts.com/catalog/shopcart/911E/POR_911E_engine_pg6.htm#item26
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 06-27-2004, 06:50 AM
No Expert
jgparker's Avatar
And it's only $10.20...
Old 06-27-2004, 09:06 AM
Fishcop's Avatar
Great stuff! Thank you Jim and JP. I'll go with the plug for the time being and then order the longer line next Pelican shipment.
Cheers
John Forcier
Old 06-27-2004, 04:43 PM
