bypass
hello ,
I will put a carrera 3.0 oil pump and I will change the pressure relief valve , but I'm wandering what are the consequences if the bypass is not drilled in the block (a pre 73 one) ? I ve seen some engines (before 73') which have not the new bypass and they were ok.... thanks for my knolwledge :) :) |
You will have oil pressure problems if you use a newer-style oil pump with the older-style cases without doing the bypass. If you are not going to do this simple mod, then use your original pump...
-Wayne |
ok thanks wayne :)
The pump will function the same and oil pressure will be the same. I have run an SC pump a early case with no mod and no issues. |
| All times are GMT -8. The time now is 04:08 AM. |
