-   -   SOCAL source for MFI Injector cleaning? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/170441-socal-source-mfi-injector-cleaning.html)
KevinG 07-01-2004 01:21 PM
Does anyone know of a Southern California source for MFI injector cleaning and flow testing? Only reason is for potentially faster turnaround. Cost and overall impression would be appreciated if available.
Thanks!
Henry Schmidt 07-01-2004 02:05 PM
We do all MFI servicing along with:
Services offered by Supertec Performance
Bosch MFI
MFI throttle housing rebuild
MFI pump rebuild
Custom MFI stacks
Custom MFI injector lines
Supertec hand choke assemblies
New and used parts
Bosch ignition distributor
Overhaul
Recurving
Pointless conversions
New and used parts
Twin plug conversion
Bosch CIS
Rebuild fuel distributor
Rebuild warm up regulators
Custom made fuel lines ( high pressure Parflex , 1100 lb burst pressure 500 lb
operating pressure)
New and used parts
Head work
Valve jobs
Porting
Twin plug
Engine rebuilding ( 911/930 air cooled only )
Stock
Hi performance
Transmission Rebuilding
Stock
Special application
Vintage racing, V8 conversions
Special ratios
Transmission Parts
Over 150 Porsche Transmissions in stock
901, 912, 911, 915, 931, 930
All stock ratios on the shelf
Main shafts, R&P, nose cones, cases, side covers and speedo drives.
Differential housing by the dozens.
Supertec Performance exclusive products
Supertec head stud kits
(State of the art aerospace design)
930 Turbo Carbon fiber air filter assemblies
(30% increase CFM and increase ease of maintenance
Cylinder head spacer for 2.2 to 2.0 head conversion
(Allows for big valve heads to be installed on 2.0-liter cylinders)
Differential ring gear spacer
(Late limited slip in early box)
Cylinder spigot reducers
(Restore early cases to original spigot size, or turn 7R case into 2.0 – 2.4 spigot size)
KevinG 07-01-2004 03:14 PM
Thanks, Henry
Do you have an approximate turnaround time for cleaning and testing MFI Injectors? Cost?
Thanks!
Langers 07-14-2004 12:59 AM
"Pointless conversions"
What, like putting a WRX engine in a 911? ;)
Henry Schmidt 07-14-2004 11:02 AM
We will clean and test your injectors for $35.00 + shipping and turn around is one day.
Why not put the WRX engine in your John Deer riding mower and leave the 911 alone. :)
Langers 07-14-2004 04:48 PM
That would be one damn fast mower. Pity we're in the middle of a drought here and there's no grass to cut.
P.S. tried your website last night and it wouldn't load; comes back 'page not found'
KevinG 07-14-2004 04:55 PM
Henry -
They will be on their way tomorrow. Thanks!
Glenn Yee 07-14-2004 11:33 PM
RC Engineering. Find them on the net. They are So Cal based. They'll send a report as well.
Glenn Yee Motorsports, LLC
