Identify these two parts
Part number 1.
Came off the engine somewhere, I just can't think where.
Part number 2.
These came with the rebuild kit. Where do they go?
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 07-04-2004, 02:33 PM
I cant tell about item 1 but 2 are valve stem seals, They sit on top of the valve guides inside the springs
HTH
Neven
Old 07-04-2004, 02:58 PM
350HP930's Avatar
The first item is a vibration isolator. They are used to isolate items like fuel distributors and regulators that are mounted on the motor from engine vibration.
Old 07-04-2004, 04:05 PM
magic930's Avatar
I do' know what it is... but we betttter get a pho-to of it! (Steve Martin, Saturday Night Live)...
Actually I think 350HP930 is correct, number 1 looks like one of the fuel distributor mounts. Although it may also be one of the mounts from an airpump if your car had one.
Old 07-04-2004, 04:34 PM
That was my guess on number 1. Just don't know where it goes. The two likely places I found doesn't seem to fit it appropriately. As for number two, I wonder it the guy that did my heads put them in. Are they necessary on SC's or are they for different years?
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 07-04-2004, 07:19 PM
Machine shops usually put them in from their own stock.
Old 07-04-2004, 08:05 PM
vichang4's Avatar
I had my heads done at competition engineering. Walt installed seals out of his stock, and I sent him the seals out of my gasket kit. Therefore no double charge for the seals.
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 07-04-2004, 09:52 PM
al lkosmal's Avatar
Number 1 does look like the vibration isolater for the air pump. Get rid of the air pump and you won't need the isolater. Did they have air pumps on the 81 SC's. I don't think so. Hmmm
RGruppe #669
http://www.x-faktory.com/
Old 07-05-2004, 03:07 PM
the rubber piece is used in two places on later SCs to support the front of the airbox. one to a metal bracket that attaches to the throttle bellcrank plate, and one at the passenger side corner. the metal piece though, doesn't look familiar. yes, the stem seals are necessary.
206 637 4071
Old 07-05-2004, 03:25 PM
When I replaced my 28 tube cooler i saw a part simliar to # 1
The vibration damper was mounted to the cooler and the mounting bracket was for one of the horns....
Old 07-29-2004, 09:10 AM
350HP930's Avatar
Yes, those isolators are used all over the place on porsches.
Old 07-29-2004, 04:28 PM
