-   -   New valve guides (http://forums.pelicanparts.com/911-engine-rebuilding-forum/172812-new-valve-guides.html)
garibaldi 07-16-2004 05:11 PM
New valve guides
here are some special valve guides I just made for a 911 motorhttp://forums.pelicanparts.com/uploa...1090022995.jpg http://forums.pelicanparts.com/uploa...1090023017.jpg http://forums.pelicanparts.com/uploa...1090023033.jpg http://forums.pelicanparts.com/uploa...1090023053.jpg http://forums.pelicanparts.com/uploa...1090023076.jpg
BURN-BROS 07-16-2004 05:13 PM
How are they special? and hats off to you photo abilities,those are so great pics.
garibaldi 07-16-2004 05:44 PM
I had to make them for a set of head that had a previous install of valve guides by another shop that didnt install the guide properly and cracked 5 of the 6 intake guide bosses. So after I had removed the new guides, and welded the cracks, and reshaped the ports, I had to rebore the guide hole to oversize in order to get the hole straight and clean , that is why I made these guides, in order to fit the repaired heads. Not only does that allow me to make the guide to my dimensions and liking, but I can also make it out of the material I want.
http://forums.pelicanparts.com/uploa...1090024638.jpg http://forums.pelicanparts.com/uploa...1090024777.jpg http://forums.pelicanparts.com/uploa...1090024908.jpg http://forums.pelicanparts.com/uploa...1090025038.jpg
garibaldi 07-16-2004 05:47 PM
This repair also prompted the replacement of the valve seats as well form the heat of welding repair. Turns out that the old seats which had previously been replaced were in at too little crush anyway, so the customer could have lost a seat during operation. After removal, I had to rebore the seat bore, and make oversize seats for the head, since the old seats, were already .030 over Porsches oversize valve seat size. Again, this allowed me to ensure concentric cuts with the guide bore, and achieve the crush I desired, and make the seats out of the material I like.http://forums.pelicanparts.com/uploa...1090025270.jpg
jgparker 07-16-2004 06:40 PM
Beautiful work and great pictures. Do you just do P-car work, or what is the nature of your business? What camera are you using. I am in Awe.
Thanks,
JP
Fishcop 07-16-2004 07:22 PM
Definitely couldn't think of a better way to demonstrate your skill!
Alan Cottrill 07-16-2004 08:01 PM
your skills are amazing.
but I have to ask, what was so special about these heads? Why not just find some better cores to start with and use off the shelf parts?
BURN-BROS 07-16-2004 08:06 PM
Twin plugged heads for a 3.2 I am guessing. There is enough work into them to warrant it.
edit .. Niresist rings for turbo application. Did I quess right?
garibaldi 07-17-2004 12:03 PM
No, they are for a 3.4 turbo motor. See, the heads were brought in for me only to clip some material off of them to raise the compression, but once I got them and saw the cracks that was the first red flag, then when i pulled out the valves to look closer, and measured the stem to guide clearance and found both .0015 on both intake and exhaust (Way too tight esp for turbo) that was second red flag, then when I measured the crush on the niresist ring and grooves, too tight, third red flag, The valve job had been done so that the valves were sunk so far down in the seat, that the head wouldnt breach the combustion chamebr for about the first .030 of lift, so why run a bigger cam? it went on and on . True, it would have been easier to just get new stuff, but the customer had already spent a lot of money having all the work done elsewhere. The heads had been cut, grooved (Which I dont like), seats had been replaces, a valve job done, they were twin plugged and guides installed (And cracked the heads) and they were ported. SO he had already sunk a ton of money into them. Unfortunatley, I had to undo all of the work he had already had done in order to correct that. Hence the new guides, the welding, the seats, etc.
During the process, realizing that the amount of material I would have to remove to get his desired compression would not be practical since it would require removing too much form the heads, I opted to have pistons made for me by Wiseco, who we use for all of our projects when we need things made in terms of pistons (There is a past recent post on them) . The orginal Mahle 3.4 kit he had gotten was supposed to be 7.5:1, but when I poured the motor, and this was after I had cut the heads again, did the valve seats so that valve wasnt buried in the head, it still only poured out to 6.9:1 with the thinner base gasket, so go figure. That is why ot is so omportnat to check all of this stuff and not take any of it for granted.
Beleive me, it certainly would have been easier to just start with new stuff, and I gave the customer the option, but he wanted to keep it, so away I went.
North Coast Cab 07-18-2004 04:52 PM
Christian,
Awesome work. What does your shop do? I'll be in Summit, NJ this weekend and I'd love to check it out.
John
garibaldi 07-18-2004 04:59 PM
We do all specialty machine work, engine building, R&D, and cook food
Doug Zielke 07-19-2004 07:34 AM
:D :D :D
BURN-BROS 07-19-2004 07:45 AM
The culinary arts are not to be taken lightly. ;)
garibaldi 07-19-2004 11:54 AM
I can't think and work if my stomachs growling
