Question New rebuild oil leak
I had my 1976 911 2.7 rebuilt. Have not started yet due to oil
dripping out of exhaust ports. I have turned the motor over several times and sounds fine. Also smell gas in oil. What would be the cause? Anybody?
Old 07-01-2004, 05:31 AM
1) How much is dripping?
2) How much oil did you use during assembly?
3) Gasoline may be residual from the intakes when you took them off and then re-attached.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 07-01-2004, 07:15 AM
A few drips a day... Could it be that the rings are not seated yet?
Old 07-01-2004, 07:30 AM
That just doesn't sound right unless you put 9 gallons of oil in. There is no way that oil could be leaking out the exhaust ports unless you didn't have rings on the pistons (doubt it) or you didn't get the heads seated onto the cylinders (doubt it again). Are you sure they are leaking out the exhaust ports and not leaking from somewhere else and running down by the exhaust ports?
1997 BMW M3 (Hail)
1985 928 S (Sold)
Old 07-19-2004, 02:03 PM
