-   -   Last question on timing, did a search no luck (http://forums.pelicanparts.com/911-engine-rebuilding-forum/173469-last-question-timing-did-search-no-luck.html)
Jim_0068 07-20-2004 10:40 PM
Well i was trying to finish the cam timing tonight but ran into a small snag. According to Wayne's book my brother's 911T uses a high lift cam sequence to time the cam (even though it is a CIS motor). I came to this conclusion due to the 2.6mm of overlap the cams are spec'd for.
According to Wayne's sequence i am to torque down the cam bolt to its 110ftlb value but that is a PITA MAN! What is the point of this? Would it be acceptable to torque it to like 60lftlbs or so and then do the timing?
Only reason i ask is because i am having a hard time keeping the cam from moving as i am tightening the cam bolt and yes i do have the tool to hold the cam
Jim
ChrisBennet 07-21-2004 12:37 AM
The setting will change when you tighten the bolt/nut. Tighten it some (say 60 ft lbs) as you go along (moving the pin) and when you arrive at the setting you want, torque to spec and recheck it.
-Chris
Jim_0068 07-21-2004 09:36 AM
Thanks Chris...you've been a lifesaver!
ChrisBennet 07-21-2004 10:04 AM
Sorry I can't get out to the garage to take a picture. There's been a wigged out blue jay in my garage all day who's too stupid to fly out. When I go out there he gets all stressed like he's overheating. Maybe it's really a Blonde Jay. :D
-Chris
EDIT: Ooops wrong post.
Jim_0068 07-22-2004 12:10 AM
Hey i figured out a good way to use the P204 tool to tension the cams...i'm going to make a post about it for people in the future
