-   -   3.6/ 993 experts????? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/173780-3-6-993-experts.html)
rick conrath 07-22-2004 01:59 PM
I have posted a few times and made call to a few engine builders without sucess. What is the finish on the 993 chain cases? If I wanted to restore the tired "black" finish prior to a rebuild....who can do this? Can they be powder coated?
Rick
'78 930
ischmitz 07-22-2004 04:48 PM
I know folks that have powdercoated the covers. I don't know about the cases. But I think It shouldn't be a problem as long as you mask off the oil galleys and the gasket surfaces properly. As far as I know they are made from Magnesium and the finish is corroded blackened magnesium :) Sorry, I really don't know what the finish is.
rick conrath 07-23-2004 08:09 AM
Thank you. It's amazing to me that this is such a mystery. The finish looks almost like a composite type of finish applied over the metal substrate.
Rick
'78 930
racing97 07-23-2004 10:46 AM
Okay but don't laugh, We restore the finish on Hewland Gear Boxes with a Map gas torch and black BBQ paint.
The finish on the Porsche is a result of Pickling at the end of the casting process, I know of no place to redo this process.
Best Regards
rick conrath 07-23-2004 11:24 AM
That sounds like a good idea. I guess that I should media blast the piece and then "pickle" the piece with a torch and paint. I guess that I could still powder coat as well.
Thanks.
Rick
'78 930
mackpipes 07-23-2004 04:42 PM
Rick,
ASC (American Stripping Co.) in Manassas did great work on my engine tin, valve covers, fan and housing when I rebuilt. Check out the pics in the Dorkiphus gallery under Ted Thomas engine drop.
BURN-BROS 07-23-2004 05:43 PM
I think the covers are fiber reinforced plastic. I know that some powdercoaters can powdercoat mdf(wood) but it is special. Check around to see if they could do them.
Aaron
rick conrath 07-23-2004 06:30 PM
The plot thickens. What about the cases? If they are plastic, I ought to be able to blast them with a soft media and get them to look new.
Rick
'78 930
ischmitz 07-23-2004 06:35 PM
Only the covers are plastic. The cases are Magnesium alloy. Ryan had the covers on the 964 3.6 engine powdercoated.
Ingo
rick conrath 07-23-2004 07:45 PM
Thank you. That helps with the puzzle.
Rick
'78 930
