Early oil pump with late pressure relief pistons
I just pulled a motor apart that had low oil pressure and had this combination. Would this contribute to a low pressure problem. Also, I have found quite a bit of metal shavings in the oil screen but all the bearings are still intact. Can I take the oil pump apart to check the internals?
73 914-6 SCCA EP Race Car
71 911T - (In Progress)
67 911 - Not long for this world
Old 07-23-2004, 06:32 PM
D troop 3/5 CAV ,162 AHC
afterburn 549's Avatar
well....you dont say which eng.- 2.7 with oil mod HAS to have the newer relive pistons in the right holes- is that your question??
Old 07-24-2004, 01:19 PM
what? me worry?
TimT's Avatar
Well since the engine is apart already, this is moot...
Did you check the pressure with a mechanical gauge? or was the low pressure just indicated on the dash gauge?
My dash gauge reads low, between 0-5psi hot.. I checked with a mechanical gauge and the real oil pressure is 15psi at idle, hot engine..
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 07-24-2004, 01:56 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Re: Early oil pump with late pressure relief pistons
No, oil pressure will not be effected by early oil bump and late pressure relief valves.
The oil pump can and should be dissassembled for inspection. It is possible that the shavings you found are a result of poor cleaning prior to the last assembly. If this is a mag case, low oil pressure at idle is generally the main bearing bore / main bearing clush is out of tolerance.
I did see one engine case that had a small piece missing from the case at an oil passage from a previous explosion.
Very rare, but find the problem before you assemble the engine.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-25-2004, 09:34 AM
