nreed's Avatar
Fly by wire
Anyone have any experience with converting the mechanical throttle linkage on a 911 with an electronic servo system?
My next project....
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 08-05-2004, 09:08 AM
Norm
No, but I can't see a problem, A Search for control circuits for a servo found http://www.epanorama.net/circuits/servo10v.html
I'd be more worried about how it faided though, with the mechanical systems, they mostly fail to closed, a servo losing
power will simply stop, a worst case is that it went berserk
Neven
Old 08-05-2004, 09:34 AM
Drive it like u stole it.
jonesb930's Avatar
I think the Motec ECU's can deal with them. You really need to be carefull just doing something home made in this area. As Neven said, "worst case is that it went berserk". That would not be good. I thought about this option as I have a Motec M600 on the shelf. The more I thought about it the more I liked the old method.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 08-09-2004, 12:25 PM
I don't see why anyone would want to do this. The response will always be slower than a mechanical linkage.
-Andy
Old 08-09-2004, 12:34 PM
nreed's Avatar
I am exploring the idea of throttle servo because my new ECU can accomodate it. Some of the newer cars have drive by wire. I suppose it depends on how fast the servo is. Also, if it does not have to move much mass a servo might work well in most cases.
Norm '86 930
Old 08-09-2004, 12:44 PM
jonesb930's Avatar
It would be really cool to tie this into the tracktion control system. It would make our old cars handle like the new ones.
Bill Jones
Jupiter, FL
Old 08-09-2004, 01:09 PM
KobaltBlau's Avatar
what benefit do you expect? does your new ECU have traction control? is it a commercial ECU or a grassroots ecu like MegaSquirt?
Andy
Old 08-09-2004, 01:12 PM
why?? steer by wire would be more interesting. how lucky do you feel?
206 637 4071
Old 08-10-2004, 01:43 PM
KobaltBlau's Avatar
yes, you could hook it up to a microsoft force-feedback joystick! and hope for no driver bugs!
Andy
Old 08-10-2004, 03:18 PM
And since there aren't any good drivers for 2000 or XP, your car would be tied to 95 or 98.
*shudder*
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 08-10-2004, 05:33 PM
350HP930's Avatar
I too ask why since a lot of the fun in owning a 930 is controlling the traction with your feet.
Old 08-12-2004, 06:42 PM
Author of "101 Projects"
Wayne 962's Avatar
-Andy
Agreed - this is a solution looking for a problem...
-Wayne
Old 08-17-2004, 03:42 PM
