-   -   3.2 w/46mm Webers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/174790-3-2-w-46mm-webers.html)
gumba 07-28-2004 08:28 AM
3.2 w/46mm Webers
Someone told me you could have the 3.2 DME reprogrammed to run the ignition only. Does anyone have experience with this set up and knows someone who can do it?
Henry Schmidt 07-30-2004 07:51 AM
It seems reasonable that you could burn a new chip with a desirable advance curve and run your DME for ignition only but why would you. If you have a functioning DME brain and harness, why not sell it. They seem to sell used for anywhere between $600 and $800. Then take that money and buy a programmable crank fire unit. You will probably break even or a little ahead and end up with a much nicer arrangement.
That's my thought anyway.
gumba 07-30-2004 07:58 AM
Is there a programmable crank fire unit available for less than $1000. I've only heard of the Eletromotive TEC3 at around $2500.
Henry Schmidt 07-30-2004 09:02 AM
Crane, Jacob's, MSD all make crank fire ignitions for less than $1000.
Electromotive Tec 3 is and engine management system. It controls the entire engine, spark, injectors, boost control, knock sensors etc. Electromotive also makes a stand alone, fully programmable crank fire that cost around $1100.
Tinker 07-30-2004 01:52 PM
Henry,
So out of the ones you've mentioned, do you have a preference?
Tinker
