MFI Delivery Rates
Hi
Has anyone ever measured/graphed the delivery rate of an MFI pump versus the Rack position? If you have are you willing to share these measurements? TIA Neven |
Neven,
The basic reason no one goes this far with MFI is that there isn’t anything you can do about it. The MFI “map” is cast in stone … well, steel. Short of regrinding the “space cam” there is not much way to tweak it other than the normal adjustments. If you want to go that direction, EFI is the way to go. You can sit there with your laptop, engine dyno, and sensors. You can re-map it any which way you want. You can run a MFI pump on a carbureted engine on the dyno and measure the flow vs. rack position, recording the number of revolutions and volume of fuel. Considering where I think you want to go, this is an important measurement. You can build a bench test also. Best, Grady |
Grady
I think Henry might have beause I've seen a picture of a pump he's modified and pulled out all the volumetric correction. As an aside the 'racing' MFI pumps had no volumetric controls. The reason I ask is that I'm going to pull out the control circuit and control the rack with a servo driven by a megasquirt, an 'eMFI' system. You might wonder why I'd bother, The MFI system has great fuel delivery (200 psi atomisation, sequential, independant of manifold pressure) , lousy control (levers, cams etc). If I do this I'll be able to 'tweek' the MFI system with the same accuracy of an EFI system, If I re cam the engine, I can remap the megasquirt. I'm also going to permanently install an LM-1 AFR and run closed loop Neven |
Very nice idea to replace the space cam with an electric servo motor + control electronics. Are you measuring intake vacuum also?
If interested, I have access to the rebuild manuals and calibration procedures, but only in september. I can send you photocopies if needed. I like your project. Andreas |
Andreas
I have the factory stuff but that is all based in the space cam calibration, Whatl I really need is: 1/ Is the delivery rate linear to rack position 2/ What is the delta in delivery rate linear to rack position The megasquirt uses a map sensor (intake vaccum) Other inputs will be 1/ RPM 2/ TPS (Throttle Position, I'll put in inside the pump 3/ 'Coolant Temp', (again a sensor inside the pump) If you are interested I'd suggest you read the megasquirt info Neven |
You could most likely measure this pretty quickly with some graduated cylinder(s). Suspend the injectors over the cylinders and turn the pump over manually 5 or 10 times until you have sufficient volume to measure in the graduated cylinders. Repeat with the rack full in, full out, and then some increments in between.
The pump doesn't even need to be attached to the engine, as long as it has sufficient fuel supplied to it. Someone should confirm this for me, but you might want to use some alternative and less flamible liquid then gas while you are doing these experiments. |
Nelven,
I have a 2.2 E with MFI in my car, plus a megasquirt computer I assembled for another project, last year. Megasquirt II will have stepper motor control (as you undoubtedly know), so I've been thinking along the same lines. Actually, I was thinking more in terms of keeping the MFI pump pretty much as it is and using the megasquirt to drive a stepper motor to act on the lever that the MFI thermostat normally works on. With Megasquirt II, I figure that scheme is implementable by changing some code alone. Would be nice to have wide band O2 sensing too ! And then use all the unused computer power to work the ignition maybe. My problem is, I can't really write code, although I might have a go at doing it in C, again with the new Megasquirt II. Can't wait for the new hardware to become available Michel Richard |
John
Yes, But its not quite that simple, fuel delivery is measured per 1000 revs, A bosch test bench does this automatically, I will get a FI tech to do this if I have to I just thought there may have been someone who'd already done this Neven |
Michel
You are on the same page! I thought of a stepper originally, The problem with stepper is that they move relatively, ie they can 'get lost' if they dont pass thru a reference point. So i decided to a futaba servo with a linear converter (see http://www.emsjomar.com/linear.aspx) The code is so basic as to be trivial instead of triggering the injector, (timed to the points, for a duration) you simply output a pulse between 1 & 2ms long every 10ms, I dont think it would be more than a couple hour work Neven |
Neven,
I have'nt looked at my pump closely enough to figure out how to set something up to act directly on the main rack. Are you thinking of splitting the pump in two and removing the whole governor section ? As I said, trivial and code don't go together well in my vocabulary, so any help from you in that regard would be very welcome. I would love to make a contribution to your effort in return. I understand that the 3.0 SC/RS race cars used some sort of Kugelfishcer pump with electronic controls on it. Do you have info on that ? I've only recently gotten my engine to run fairly well, so I'm not too keen on taking the pump off to measure flows. The other poosibility I have dreamed up is to get rid of the pump entirely and fabricate short individual runners to fit between the heads and the MFI throttle bodies. The runners would have provision for installing efi injectors as well as a small port used to measure intake air pressure. I have made drawings for the runners and I have a small machine shop in my basement where I could fabricate them fairly easily. Actually, that could be my contribution, if you need a part or two fabricated, let me know. In all cases, head temp would be measured through some of those small wire contraptions that are screwed under a spark plug. Michel |
Neven,
I'm not sure the Futaba servo would be able to develop the force necessary to reliably move and hold the rack or that it could sustain the temperatures of an engine compartment. The pump does get pretty hot, and a servo screwed to it would get very hot too. I would investigate that General Motors IAC motors. If they can develop the force required they would undoubtedly be much more reliable. Making a fitting to fit them in place of the MFI thermostat would be trivial. Michel |
Funny how things happen, I was thinking about this very same thing 2 days ago. Except it would be for boost application/correction. the Gm IAC was my first choice. You guys stole my idea!
Aaron |
Michel
You'd be surprised about the futaba servos, go to http://www.futaba-rc.com/servos/futm0029.html, They position with a very high degree of accuracy, can generate up to 194 ounce/inches of torque and are designed for hostile enviroments. (RC Cars and Helicopters). I've bought a couple of pumps on Ebay and was going to gut the control portion, Ill then design somewhere to mount the servo A std servo with the linear converter generates 1.5Kg of force, with a high power one that would be over 6Kg. The should be very little force required to move the rack, its only twisting the pistons of the pump Best part, the servo costs about $24USD with the linear converter. If you go full EFI you lose all the MFI advantages. As for measuring the manifold vacuum, Its already there, tap into the vacuum advance pipe to the distrubutor. Neven |
Michel
I just had another thought, It is easy to determine the required rack positioning force as the racks are 'passive return' via a spring Therefore the force of that spring is in excess of the required positioning force Neven |
Neven,
You are right, I am surprised by the Futama servos. I'll look into them some more. As far as MFI is concerned, the only advantage I can see that will remain if the whole governor section is removed will be the high pressure of injection. I must say I've always thought that was a bit overated as an advantage. My guess is that if the factory used electronic/MFI injection on the early eighties SC/RS cars, it's because they were getting more power than was available with the then available K-jet or electronic systems. I believe the factory racing teams have now moved to all-electronic, which would mean that current electronic systems are better. Still, it's certainly an interesting project, and I'm actively looking into it. My 2.2 E is in a 914, which means I have neither stock 911 intake or exhaust . . . and means that I can't expect the MFI to run perfectly well. As I saidc, if you can help me with some of the code stuff, I'll be happy to machine some parts, if you need help in that area. Cheers, Michel |
Michel
Thanks, drop me an email off list neven@mwk.co.nz and I'll keep you informed. I personally think the MFI pump has great advantage, Sequential (MS isn't), High Pressure, Absolute Metering (doesn't require a constant pressure differential). Quote:
Look for an MFI pump on ebay should only cost $100-$200 Neven |
It sounds interesting, but why not just use EFI with the MFI stacks?
The MFI pump costs horsepower and the drive belt can come loose. Also, the rack controls fuel delivery to all cylinders equally, you don't have the ability to give individual cylinders more fuel in response to higher CHTs. Cool idea, though! |
EFI with the MFI stacks is a possibility. But The Megasquirt system currently available does'nt do sequential injection and EFI injectors don't use the sort of pressure that MFI does.
The idea is to try to devellop electronically controled MFI, by replacing the stock mechanical governor system by a computer and a servo motor. Megasquirt, which is what we want to use because it's open source, won't let us customize injection for each cylinder. The coolness factor, at least for me, is certainly a factor. Michel Richard |
John
I'm not really doing this as an all out racing solution. I'm currently restoring a '73E. So if I get this going then I can retain a 'stock' look and get added performance & economy. Having said that I'm also interested to see how it goes. Electromechanical injectors are not perfect, They have an opening delay and can only deliver fuel at a constant rate. The main limitation of the MFI pump is its fixed VE 'map' so this removes that and allows for me to 'play' with intake, exhaust and cams and still get an optimal afr I'd ask the question, why do so many of you guys build 2.7/2.8 MFI Motors? Neven |
I've also had that thought.
If this can be made to work, MFI becomes available for a wide variety of engines. Michel |
It actually sounds like the Kuglefischer MFI system that BMW used for their 1.5 liter F1 Turbo engine. That too was an "electronically controlled" MFI system.
This is a way cool idea, guys. Be sure to post here as you work on these projects.
One thing that would be useful to make progress would be an old MFI pump that I could take apart and use as a mule for things that will need to be fabricated.
If anyone knows of one for sale, please let me know. I'll pay a reasonnable amount for an old pump, does'nt need to be an actual working one. I'll also post on the classifieds. Michel Richard michrich@videotron.ca |
41 mm butterly, stacks, linkage and custom fuel lines. http://forums.pelicanparts.com/uploa...1091737097.jpg http://forums.pelicanparts.com/uploa...1091737136.jpg |
Henry
What has been done to the pump? It looks seriously modded Neven |
Have you seen this before?
http://www.pelicanparts.com/techarticles/911_MFI/Bosch%20_More_MFI_Repair_Instructions.pdf |
Yes but I'm not sure what 'adjustment distance' means and if it is the rack position it seems stange that it appears to not be directly related to delivery volume ie Under part load
400rpm, 4.4mm = 12.5-13.5 and 3000rpm, 3.8mm = 12.5-13.5 So it seems to be a measurement before the space cam, what I want is measurement after the cam, ie the rack movement Neven |
Henry,
-Does that include the MFI pump? -Will the stock '72 air cleaner fit? -Is this a good "street" setup? - What other changes will this require to maintain the "stock" 911T driveabilityand performance? -Stock fuel pump? -Will the idle-speed adjustment, etc still be required? Terry Hastings |
Terry, maybe you know this but those stacks are for a bigger motor. I believe that the motor pictured is a 3.5 race motor. I also don't think that the MFI pump is included; this is just the induction. For 2.7 or less you can use OEM parts, depending on your RPM (high RPM motors need more air, of course).
Here's a picture that I found on the web, but unfortunately it seems that the pump was mounted under the intakes and so is almost never pictured. http://forums.pelicanparts.com/uploa...1091827703.jpg |
wow John, that is very cool. Thank you for putting that post together. It seems that even modern EFI could not deliver the fuel in such a short time, perhaps only the new common rail diesel injection is in this ball-park for a fully electronic system (just a guess, but it runs at much higher pressures than gas EFI).
I'm not sure I understand what is meant by a "spiral" in this case. I read that the servo motor acts on this "spiral" . . . is it really like the rack that is found in our Bosch pumps ?
It looks more and more like Neven's idea of a servo motor acting directly on the main rack is the way to go, as opposed to a motor (servo or stepper) acting on the little lever that the normal MFI thermostat acts on. The more I think about it, the more Neven's idea sounds better. The force to move the rack is quite small, I believe: the repair book says to use a "biro" to move the rack, using only very little pressure to see if it's stuck. I suppose the force required could be greater when the engine is running, but there is no indication anywhere that that is so. Certainly, the force required at the gas pedal does not appear to be any different between a carbed car and an MFI car, and the force required to move the "fuel" lever on the pump when the engine is running is small. Can't wait to lay my hands on a "play" pump to do some real figuring. None on ebay right now, though. Michel Richard |
Anyhow, here's an explosion of the key MFI components: http://forums.pelicanparts.com/uploa...1091882031.jpg Note how the back and forth movement of the rack (#9) rotates the plunger assembly (#7 via #8). The way that this rotational movement varies the fuel volume pumped by the plunger assembly is as follows: http://forums.pelicanparts.com/uploa...1091882140.jpg Note that the fuel flows in from the left and out the top. Notice how the spiral groove in the plunger can vary the actual closing event based how the plunger is indexed. Examples #1 through #3 shows the plunger alignment for starting (full rich) when the groove never sees the port on the left as the plunger moves up and down. As a result a full stroke of fuel is injected out of the injector. Example number #4 through #7 show the plunger alignment under normal operation. While the plunger stroke is the same, the groove on the side of the plunger can delay the actual closing event by upwards to half of a stroke, kind up like a long duration cam can reduce the CR of an engine. The result is less fuel is pumped out of the nozzle. Now going back to the BMW example imagine that you pitch everything in the first picture before the control rack head (#2) and replace it with a stepper motor and computer. What would happen if the minimum adjustment step of the motor was too large compared to the required adjustment on the rack? You'd most likely find that will flutter back and forth between the two closest steps. Instead, picture a threaded screw pushing against the control rack head and the motor turns the screw. This would allow virtually limitless adjustment of the rack based on the pitch of the screw and the rotational speed of the motor. I suspect that this is the type of arrangement which the BMW engineer was describing. |
John
Firstly they used a 'servo' and not a 'stepper', Servos are analoque, so wouldn't have a discrete increment. The spiral would be how they converted the rotational position of servo to the linear position of the rack, AFAIK Bosch own Kugelfischer. The Futaba Servos have a response time of 0.2s for a 60 degree change, I think this will be responsive enough Neven |
| All times are GMT -8. The time now is 12:19 AM. |
