3.2 CAB's Avatar
Chain Cover Pics
Here is the way the oil versus the right chain cover looks. You can see it makes a couple of zig zags, I have the fitting circled on one pic where it connects to engine, it looks like the only way that fitting could be touched is by dropping the heat exchangers. I don't want to do that. I will take the hose fitting end loose and see if that gives me enough room to get the cover out, then I can check the tensioners out and hopefully see what is causing the rattle noise. Thanks.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-05-2004, 07:44 AM
I think if you break the line loose at the passenger side exhaust valve cover area (where it connects to another hose) you may be able to pull the line down enough to clear the chain cover. even if you bend it abit you should be able to bend it back no problem. I have done this on my cars but I don't remember having quite that much overlap there.
-Andy
Old 09-06-2004, 01:25 PM
that car looks like it's going fast while parked imo.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-07-2004, 11:43 PM
