-   -   Listing places to recondition alusil (http://forums.pelicanparts.com/911-engine-rebuilding-forum/176507-listing-places-recondition-alusil.html)
mike95125 08-07-2004 04:30 PM
I thought that it would be a good idea to list all of the shops, their info and prices that recondition alusil cylinders. So far I have found:
Motorworks on Island st in San Diego - $32 each
kstylianos 08-08-2004 09:50 PM
I'm just curous what do you mean by recondition?
Does this process use the special machine and paste to help promote new ring seal?
If so, this is probably a good deal (and news) for Alusil folks.
Porsche_monkey 08-09-2004 08:23 AM
Larry Taylor - 905-840-2500 Brampton, Ontario, Canada (probably just a bit north of you).
Lots of aircraft/Vega experience.
mike95125 08-09-2004 12:26 PM
Charlie,
Answer is, Yup! Exactly that.
Thanks, PBH.
mike95125 08-12-2004 05:40 PM
Paul,
I just talked to Larry, what a hoot! He is very sharp as well.
He quoted me $19-23 each, but I am not sure if that is CDN or USD. He new all about the stuff. He called it T-390 hypereutechtic alluminum sillicone.
thanks again,
Mike
Porsche_monkey 08-13-2004 06:23 AM
Seeing as he is a Canadian living in Canada....
Mike: let me know if you are using Larry, I could stop by and inspect his work for you.
dshap 03-19-2005 11:26 AM
Does anyone know if Larry ( Brampton, Ont ) has an email address. I have 6 Alusils that are candidates for this. Can the same pistons be used after the treatment or does he change them over to Nikasils? There is some scoring on the # 1 cylinder ( Half of the second compression ring got jammed in the piston ring groove and did some damage ). Not sure if this cylinder can be reconditioned or look for new one. The other 5 are good.
Dan
