WydRyd's Avatar
Question 1K Service after complete engine rebuild...
Hi gang,
It's nearing 1,000km's since my engine rebuild and I was wondering what's typically done at this 1K service?
I have stayed under 4Krpms religiously and not driven her under load at all.
Anyway, is it just an oil flush, new oil filter, check for leaks and check valve clearances, or more involved than that?
How much time does it typically take to check valve clearances?
Advice greatly appreciated.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-09-2004, 04:44 PM
Friend of Warren
You have covered what needs to be done. If you are checking the valves yourself and it is your first time, give yourself 3-4 hours. Once you do all of that, you can start running the engine up to redline.
Kurt V
Old 08-09-2004, 06:39 PM
WydRyd's Avatar
OK thanks for clarifying. I won't run a synthetic oil just yet. I might go with a light-weight dino for a further 4,000km's and then run synthetic.
Merv
'89 911 Turbo Cab
Old 08-09-2004, 08:48 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
I'd also double check the head stud torques while the valve covers are off. Don't loosen and re-tighten, just check and tighten as necessary.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 08-09-2004, 09:11 PM
WydRyd's Avatar
I have had ARP head-studs fitted. Could they loosen?
Merv
'89 911 Turbo Cab
Old 08-09-2004, 09:38 PM
Author of "101 Projects"
Wayne 962's Avatar
Not likely, but worth a check. If all is good, they won't turn at all, and your wrench will just click...
-Wayne
Old 08-10-2004, 12:28 PM
WydRyd's Avatar
Thanks guys! BTW, what should the torque settings be for the head studs on a turbocharged Carrera engine?
Any recommendations for a really good lightweight Dino oil?
Merv
'89 911 Turbo Cab
Old 08-10-2004, 05:39 PM
