Jubbie's Avatar
Should I be worried about this fan housing weld?
Hey Guys,
Just putting back together my engine and I noticed these welds on the fan housing at the base of the struts that hold up the alternator. Weld looks somewhere between OK and sloppy and the cracks are still visible where the weld is not. I figure anyone who knows how to spell TIG welder should know what they are doing, but do you guys think this is a serviceable part?
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 08-13-2004, 07:27 AM
fancytown
You should be able to locate a good used one cheap.
1989 Cadillac Brougham
1978 911 SC Targa w/ 3.0L to 3.6L to 3.2L conversion - sold
1972 911T Targa - sold
Old 08-13-2004, 07:31 AM
garibaldi's Avatar
Oh, I thought that that was a bird poop.
You can either get another one, or grind that down and have it re welded by someone that is little better
Christian Garibaldi
Im a photographer now, so I dont know jack sh#t about cars anymore, I sold my knowledge on ebay
Old 08-13-2004, 08:02 AM
as long as the tips of the fan blades don't rub on the housing when the belt is tensioned normally, it'll probably be ok. not a lot of stress there.
206 637 4071
Old 08-13-2004, 08:40 AM
oneblueyedog's Avatar
I replaced my fan shroud that had a crack like that. I rewelded it first at an aviation weld shop. The trouble with it afterwards is that the belt wouldn't stay tight with all 5 shims under the cup washer. It woud squeak revving up. It warped with all of the heat cycling and cracking.
Lee78SC
78SC coupe, Silver Metallic
Old 08-13-2004, 12:05 PM
Jubbie's Avatar
Thanks Guys,
If I go junk spelunking, what housing should I look for? Here is the fan I have. It looks like I have a early 245mm with a 1.3:1. From what I have read, the later 245mm houseings were diferent than the early houseings. So is there any special markings I should look for?
Thanks again
John F. Lewis
Old 08-13-2004, 07:21 PM
