-   -   pros/cons to boring-replating... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/177736-pros-cons-boring-replating.html)
geof33 08-15-2004 10:42 AM
Guys thinking of having a set of Alusil 3.0 95's bored to 98 (3.2) and relined with nikasil.... Good idea? Cheaper than getting new?
What are the downsides, if any... Who can do it?
jgparker 08-15-2004 12:35 PM
It's cheaper than getting new Mahles and you have a lot more flexibility on compression ratios. The down side is, the jury is still out on J&E piston longevity. I'm glad I did it, since I got the exact configuration I wanted for half the cost of new. EBS does this, and does it well.
Good luck,
JP
Alan.UK 08-21-2004 03:57 AM
If you want to bore them out to 98, I think you need to start with 3.2 cylinders, as the 3.0 95s have a sealing ring.
Good luck
Alan.UK
