-   -   HP/Torque Curve Graphs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/178316-hp-torque-curve-graphs.html)
seanery 08-18-2004 03:17 PM
I'm looking for info for 2.2 engines with the following combos:
1. 2.2 E stock
2. 2.2 S stock
3. 2.2 S pistons with E cams
can anyprint post dyno graphs of the previous listed engines?
Thanks in Advance
KobaltBlau 08-18-2004 03:37 PM
the first two should be available from original factory full power curves from owners manuals or factory data. Unfortunately I don't have either of those.
You are unlikely to find a dyno comparable to the factory curves for the 3rd combination, however. I would guess it wouldn't look much different from the E graph if you could.
sorry I couldn't be more helpful.
