It took me over 60 hours just to clean (it was REALLY dirty mostly on the outside) and another 150 to complete the rebuild. That includes a new custom wire harness, and engine management system with new manifold, injectors, turbo, exhaust, cams etc.
It took me 9 months but it has been worth it. I dyno'd it today. It is making 333HP @ 4500 and 377 ft/lb @ 4750. My turbo is too strong and there is a lot of boost creep beacuse the wastegate can't starve the turbo enough due to header design. We did not want to take it too much above 1.0 bar. |
Norm was that 333 at the rear wheels?
I'm hoping to get mine to the dyno within 2 weeks. Brian |
Hi Brian,
Yes, that's at the rear wheels on the dyno. Good luck with yours! |
Hey Norm,
Something doesn't seem right... I'd expect your hp to peak at higher RPM given the cam you are using. Another question - is the # based on 1.0 bar boost? When I dyno-ed mine last time, the dyno showed that I'm leaning out big time so we gave up @ 5700 rpm. My #s were 320hp @ 5700 and 300 ft-lb @ 5500 rpm using a .6 bar spring. I'd have thought that you'll have lots more. Maybe tuning needed now? |
That's a bummer. I was expecting much more.
Patrick : are you using EFI? |
Brian,
No- still on CIS. On the boost front, I should be a bit more careful - experience shown that ONLY on track with extended period of acceleration, my boost might creep to .85/.9 so on the dyno run, it could have been close though our run is very short each time. On a separate note re:fueling: something good but bugs me is that my wide band O2 shows that I'm still running pig rich on full boost (that's good :)), and that's before I even turn on the Andial fuel enrichment & I only have a "standard" Euro fuel head/line without the mod. But what bugs me is that everyone else seem to be running lean on theirs???? |
| All times are GMT -8. The time now is 07:35 PM. |
