This doesn't look like a 930 Crankcase?
Hello,
I've recently started rebuilding my 930 engine. The engine is out of a '89 930. However, I noticed that the bottom side of the crankcase looks a little different to what I am used to seeing. Can someone tell me what they know about this crankcase? (Is it the right case for an '89?, material?, anything else I should know?) The number on the side of the case is 930.101.103.6R and the case number up top is 930/68. Thanks! http://www.angelfire.com/extreme3/gt...earDown001.jpg |
Looks normal to me. The cases switched from the kind with the sump place to the kind like you have in 1983. Maybe that's not what you mean?
-Chris |
Chris,
Thanks, that's exactly what I was hoping someone would tell me...I'm still learning. |
holy crap, that aint no 930 case, thats from a 356!
Kidding, looks normal to me |
Christian,
Thanks for the confirmation! And on to the next question. I was thinking about sending my heads and case to EBS Racing for work. However, I was wondering what other shops everyone here would suggest? I want to shop around. (I'm not sure if there is already a post with this information. If so, please let me know.) |
EBS is great to deal with. They did my heads, turned them around in the time they told they would, and their customer service and work was excellent.
Brian |
If you would like, I can do your heads for you.
Christian,
I wanted to look into what services you can provide. Do you have a website? If not, maybe we can talk offline. Thanks |
I do hp engine building and specialty machine work. Contact me offline if you like.
| All times are GMT -8. The time now is 12:46 PM. |
