Plavan's Avatar
Sleeving cylinder... Where and ballpark $$$
Hi guys. I will be sleeving my 90MM cylinders 1mm to 89MM for my upcoming 2.5L race motor. I have already talked with EBS and they gave me a ball park of $750. I know EBS sends these out to be done. Any other ideas of who I can call for price quotes? I will also be having have the cylinders mooned.
Thanks in advance
Chad
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 09-03-2004, 02:38 PM
Licensed User
Shuie's Avatar
Jon at EBS (800) 462 3774
Henry at Supertec (714) 429-1863.
Old 09-03-2004, 03:21 PM
126coupe's Avatar
I have used ebs for other jobs have always been very happy with their work. Dont pinch pennies for this critical work
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 09-04-2004, 07:29 AM
Not sure what kind of sleeve material they have. Maybe these guys are worth a look. They've been around a long time.
http://www.lasleeve.com/
Sherwood
Old 09-04-2004, 10:24 AM
sleeves make me nervous. the bottoms of the cylinders get really thin when bored out for sleeving. not much support for the sleeve down there. that's where the piston skirt wants to slap the shizzit out of it. seen a few that broke out.
206 637 4071
Old 09-04-2004, 04:06 PM
Walker is correct, the cylinder will get quite thin. You woudl be better off Making either an iron or steel cylinder, and pressing on a aluminum heat sink to it, so you arent trying to share wall thickness between the original cylinder and sleeve. Rigidity is an issue, esp in a race motor. Pluys there is an issue in terms of the residual tension from the required interference fit asnd the thermal expansion differences between the iron and aluminum, they need alot to hold, and the thin wall section will make it prone to split.
Old 09-04-2004, 04:26 PM
Although the most expensive route, for reference, LN Engineering manufactures underbores of all mahle cylinders in billet nikasil, including those that were originally cast iron or biral. Makes it really easy to dial in an extact displacment for classes such as 2.5L, without sacrificing cooling or reliability.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Old 09-04-2004, 09:43 PM
