-   -   carbs on a 3.3 turbo? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/180837-carbs-3-3-turbo.html)
adomakin 09-02-2004 09:10 PM
does anyone run carbs on modified 3.3 turbo engines? is this not a good way of getting rid of the cis?
KobaltBlau 09-02-2004 11:02 PM
no, not a good way. Turbo plus carbs is not an easy thing to make work. The easy way is to do draw through (carb before turbo in intake system), which would make for some unusual plumbing with 2 IDAs.
adomakin 09-06-2004 11:55 AM
cheers andy, thought it may be a bit tricky. CIS for now then!
724doorE 09-06-2004 01:26 PM
MFI on the other hand has been done ;)
KobaltBlau 09-06-2004 09:32 PM
Just grind the right space cam.... Porsche knew how!
