PJMARKOW's Avatar
Valve to Piston Clearance Check
I've done my cam timing and I'am about to start on the valve/piston clearance check. This is a dummy assembly and I was wondering if I need to install the chain tensioners or can I go with the setup I used to set the timing, ie clamp on the left and tensioning tool on the right as per Wayne's book?
Cheers
Paul M
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 09-05-2004, 01:59 AM
Proceed with your mechanical tensioner setup. It's fine for checking.
Sherwood
Old 09-05-2004, 11:52 AM
