Advance curve info please
Hello,
Can anyone tell me where I can find an advance curve for the ingnition system on a '74 2.7 with SC cams. Any close proximity would be fine as I will be needing it for my pending distributorless ignition system that I am building. Any help, advise or such is greatly appreciated. -Mike |
Early_S_Man/ Warren has posted this a few times.. try his user name and distributor or Bosch or etc
Thanks again! I tried searching with no results. I just need the right words.
-Mike |
actually after a little more thought,
maybe ask a pro that has the experience with a 2.7 and SC cams for a dizzy curve suggestion. although I don't have your set-up, I'd guess that the greater fuel flow and power might might enjoy a 2.7 Euro Carrera/231.184.004 dizzy curve timed at 10deg initial with the vac line disconnected. interesting topic imo |
I have a system that I am building using the ford EDIS6 coil pack and controller with a homemade ECU done from a kit bought off line. The ECU is fully programmable and has a MAP sensor so I will have to figure out the maps for it as well. I am guessing that I may just use the stock 74 2.7 dizzy that I have with the engine and do a advance plot from it. Its a start....hell, I should probably get my engine together first.
-Mike |
try these sites for some more curves. http://forums.pelicanparts.com/showthread.php?s=&threadid=101676&highlight=distri butor http://forums.pelicanparts.com/showthread.php?s=&threadid=5432&highlight=distribu tor+lube and TimT may have an educated opnion on your needs if someone doesn't jump in here. Give him an e-mail. |
Out standing! Thanks again RoninLB. These are a good start. Unfortunately, I think that they were all for carbed engines and I will be using CIS. I intend to make my findings public so that if any one wants to make a DIS for their 911 for around $300 or less they can. The built computer is $150, but one can buy the board ($15), programmed chip ($8), components (about $40), and case ($16) for cheap and assemble it themselves if they are so inclined. I got the EDIS 6 controller, sensor, and trigger wheel from the parts yard for like $20. I am using the Mega Jolt Lite jr kit. Heck, I hope that the dizzy from my engine originally ('74) will work with the SC cams and 8.5:1 cr pistons that I just installed. Learning is good.
-Mike |
distributor curve for the SC is 0, 5, 10, 15.. I cut of the left bar #'s to tight.
http://forums.pelicanparts.com/uploa...1094681175.jpg http://forums.pelicanparts.com/uploa...1094681189.jpg |
That should do quite nicely.
THX! |
I know this is an old thread but I have the Ford EDIS ignition and was planning to use the Mega Jolt. Did you ever get this working?
I did not. My CDU died and I was not completely sure it was not because of the MJ unit and stuff in the system. In order to just drive the thing I installed another CDU and put my unit in a box. I will use it later on a different engine like my corvair powered bus :)
| All times are GMT -8. The time now is 10:33 PM. |
