3.0 SC -- Schematic for Wiring Harness
To all -- I am looking for a schematic diagram to reattach my wiring harness on a 3.0 SC engine. Any suggestions as to where I can find one on the web?
Thank you, Duane Duclaux |
Daune, do a search for 14-pin connector or the like.
You have two harnesses. One for ignition and such, one for fuel injection. You'll need to look up both.
The harnesses are built to fit where the connections go. Once you figure out a couple of the connections, the rest just falls into place. Easier said than done I know. The fuel injection harness starts from the firewall. The ignition from the drivers side. Michael |
I used the Bentley manual diagrams to figure mine out. On a couple that I need confirmation, the board helped me out. You can do a search on my name to see some of the questions I had.
Michael |
| All times are GMT -8. The time now is 06:14 AM. |
