jamesjedi's Avatar
993 Cylinders
I have searched and not found an answer....Are all 993 cylinder made of Nikasil? Are any made of aluminum? If they are Nikasil, are they all OK for honing?
THANKS!
James
Old 01-01-2011, 08:43 AM
993 cylinders are all aluminum with Nikasil-plated bores.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-01-2011, 11:38 AM
jamesjedi's Avatar
Ahhh....Steve, as usual a big thanks. Can they successfully be reused, honed or ported?
Old 01-01-2011, 01:23 PM
That depends on their condition,....
I measure them for taper, concentricity, and surface finish.
They can honed with diamond hones, however this should only be done as a last resort as that increases piston-to-cylinder clearance which is not desirable at all. One can always have them replated if that becomes necessary, but thats not cheap to do.
Cylinders are not generally "ported" for engines that never see 7K RPM as its a waste of good money. (the correct terminology is "mooned", where the bottom sides are enlarged to match similar, matching case modifications.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 01-01-2011, 01:39 PM
jamesjedi's Avatar
Thnaks Steve.
Old 01-01-2011, 02:10 PM
