Please help with 993 solid rocker conversion??
Hi all, I'm trying to convert my 1995 hydrulic 993 rockers to the solid lifter adjustable rocker set up.
I plan to track the engine and see over 7600 rpm (carillo rods) if that is a concern. Is there an affordable kit available? Can the 964 rockers be used? Are machineing and new adjusters required? Is the $1200 CMW kit a good way to go? thank you. |
All the kits I've seen are around that price FVDs is $1250 and is all inclusive.
Be sure to do the sprocket backdate at the same time. |
ted,
What are you planning on doing with your old hydraulic rockers? I'm considering swapping out my solid lifters for hydraulic. I'm still not 100% on what exactly needs to be done for everything to work tho. |
I have a complete 993 set with rockers,shafts,cams and housings if he is not selling. Let me know if you are interested.
Rick '78 930 |
rick (or anyone),
whats involved in swapping out solid for hydraulic rockers? i.e. What else needs to be replaced besides the rocker arms? |
My understanding is that you need the complete cam tower setup in order to go from solid lifters to hydraulic. I know that the cam profile is different. To go the other direction from hydrauilic to solid, you just need the converted rocker arms...a much simpler operation.
Rick '78 930 |
Thanks for the info guys.
I purchased an RS solid rocker arm/shaft kit from Patrick Motorsports in AZ. If any one is interested in my hydaulic rockers/shafts pm me for a good price. |
| All times are GMT -8. The time now is 03:17 PM. |
