-   -   inside oil tank part?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/182102-inside-oil-tank-part.html)
mattduncan 09-11-2004 12:04 PM
Im changing the oil in my '82 SC and found some "part" flopping around inside the oil tank. Does anyone know what this is? I have been overheating bad lately and am thinking this "part" may be blocking oil flow. What is it/how fix? I'm in the middle of the job now so if someone knows, please respond...
smestas 09-11-2004 02:17 PM
Does your oil tank level gauge work?
It could be part of a broken oil level sending unit.
You will see where this mounts on the oil tank by looking at the oil tank from the right rear wheel well.
http://www.pelicanparts.com/catalog/...ank_sender.JPG
palle7688 09-14-2004 04:43 PM
same as simon. loose float can block oil to engine. I've heard of this before. you should check this before running engine. you possibly have to remove oil tank to get part out of tank through level sender opening.
