Valve Springs Upside Down
Hi
I've just finished the long block and have now learnt that I should have oriented the Outer Valve Springs, I don't think this is a major though I could change them.
Any comments
TIA
Neven
73 911E 'Eva'
70 914/6 'Eric'
Old 09-13-2004, 03:52 AM
126coupe's Avatar
the bottom of the spring has slightly tighter coil
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 09-13-2004, 07:37 AM
Yes, but is it critical? The only reason I can think for orientating them is that this lessens the moving mass
Neven
Old 09-13-2004, 01:15 PM
126coupe's Avatar
Yes its critical, an upside down spring would put more strain on the rocker arm ......... check all 12 of them
28' Pace Trailer
Old 09-13-2004, 01:37 PM
The spring should have the same tension characteristics regardless of which end gets pushed. If the spring is progressively wound, the lower tensioned portion will compress first.
However, the tighter wound end would be slightly heavier, thus you don't want this end moving as much (with the rocker arm). How does that sound?
Sherwood
Old 09-13-2004, 04:48 PM
geof33's Avatar
Sherwood
Sherwood,
No to be arguementative, but the moving mass is at issue when it comes to compression. That's why progressive springs always have an orientation depending on application. If what you said were correct you could spring a sus system any old way. That's not the case though. Progressive springs always mount in one direction only, depending on where you want the load given the mass.
I agree it is critical to mount the springs correctly as the initial movement of the valve needs a lessor spring rate for control in the start of it's stroke.
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 09-13-2004, 10:55 PM
Author of "101 Projects"
Wayne 962's Avatar
I tend to agree with Sherwood's statement. As a mechanical system, the spring should respond to compression (not tension) in similar manners, regardless of whether it's placed in one orientation or the other. The force on one end is countered by an equal and opposite force on the other. Reducing the moving mass would mean putting the heavier part closer to the chassis.
I'm just speculating here - I don't know for sure.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 (October 2018)
Check out our new site: Dempsey Motorsports
Old 09-14-2004, 01:50 AM
In regards to the Springs they are basically Non-linear in design.
This manufacturing process effectively decreases the number of active coils as the spring is compressed and the rate increases.
It does not have a single natural frequency but passes through a range of natural frequencies instead. It does not effect the rate but the harmonics. It is a little more complex to manufacture and is not the cure for a materials issue.
Best regards
Old 09-14-2004, 08:59 AM
