iamchappy's Avatar
differences between 930 and 964 turbo oil scavenge pump
I am giving up on the Tilton electric pump on being able to keep up with the flow from the turbocharger, I thought I had the oil problem solved by restricting the oil going in but the symptoms have reappeared. Is there a difference in the 930 and 964 pumps in regards to how they mount on the cam cover, it will be used on a 79 3.0 sc. engine.
Also what would you recommend as the best KKK turbo or others
to replace my old Rayjay TO4B.
k27, k27 highflow?
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 09-20-2004, 06:36 AM
