mike95125's Avatar
Question Oil pump questions (x2)
I was looking over my oil pump before install and noticed that there was this sealant that goes around the base of the intake pipe where it meats the pump housing. This stuff was brittle as hell and crumbled right off. My question is do I need to replace this stuff, or is it not all that important? And if I do need to replace it, with what?
My other question is that when I look into my oil pump it looks like the two gears are actually two gear stacks. There is a bevel in the middle where the gears on the stacks meet and a subsequent line all the way to the shaft which looks like a parting that was intended. Is this correct? Does each shaft have more than one gear on it? I have the '74 pump.
Thanks for all of your help,
Mike
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 09-15-2004, 07:28 PM
AFJuvat's Avatar
Just use a god epoxy in place of the sealant - JBWeld works well - same way you re-epoxy the studs on teh back of the chain boxes
Yes, there are gear stacks on each shaft on the oil pump.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 09-15-2004, 08:02 PM
mike95125's Avatar
Thanks for the info. I appreciate it.
-Mike
-74 BMW R90
Old 09-15-2004, 10:21 PM
