Question Tool for oil pressure relief valve plugs?
What's a good tool to use for R&R of the oil pressure relief valve plugs in the engine case? I have a 73 911S 2.4L, and the two plugs look like they need the mother of all screwdrivers to R&R. I got one out, but when trying to re-torque it with a big screwdriver, crow-foot, and torque wrench, I popped off the screwdriver tip (back to Sears). It seems like there should be a tool to mate these plugs to a torque wrench, but I've not found one.
Thanks,
Brian
Brian
Old 09-17-2004, 07:14 AM
a mother of all screwdrivers, and a hammer. catch the outer edge of the notch and knock it loose. install the same way.
206 637 4071
Old 09-17-2004, 08:16 AM
dtw dtw is offline
GAFB
You can also pick up the later model pressure relief plug - I believe it's a 19mm hex style that you can slap a socket and ratchet on. I tossed my screw-type items this year in favor of the updated items. Just a couple of bucks.
'72 911T MFI VW Silver Metallic
'84 911 M491 non-sunroof Slate Blue
'01 996tt Lapis Blue
Old 09-17-2004, 10:35 AM
ChrisBennet's Avatar
Hey, that's a great idea!
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 09-17-2004, 10:45 AM
if you update to the hex caps, don't forget to update the pistons, springs and inner spring sleeve too, because the new caps have a different depth than the old ones.
206 637 4071
Old 09-17-2004, 11:28 AM
what? me worry?
TimT's Avatar
hehehe
just need to apply enough torque to compress the sealing washers..
or, just lean into the wrench a bit
not to much though..
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 09-17-2004, 07:39 PM
mike95125's Avatar
I just ordered these from pelican and they didn't say that I needed to change the springs. From what I have encountered, the only need to change the springs is for the oil bypass upgrade. If no upgrade then use same springs with newer caps. As a side note, the pistons with the holes in them have been upgraded to the ones for the upgrade as well (no holes).
This is ofcourse just what I have heard from a few sources, is this wrong? Please explain. I could be misunderstanding you.
Thanks,
Mike
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 09-17-2004, 10:53 PM
sayah's Avatar
Sorry for the crosspost, but on a related issue: Does changing the oil pressure springs and pistons to the new style after doing the oil pressure modification effect the oil pressure at all?
sayah
Old 09-18-2004, 12:03 AM
Warren Hall Student
Bobboloo's Avatar
The later type pistons with no holes are for use in crankcases from 76' on or for an earlier case that has been modified with the later type oil bypass. Replacing the pistons to the later (no holes) style piston will damage an early case motor that hasn't been modified to accept them.
What JW refers to is an even later style that goes with the later hex cap.
Bobby
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 09-22-2004, 02:05 AM
sayah's Avatar
Thanks for your response, but I have a early type case that has been modified, the problem is the oil thermostate on the top of the engine leaks becasue I believe the pressure is too great. I did replace the pistons and springs without the holes. I think this change is causing the leak. I don't know what to do since replaceing the oil o ring does no good.
sayah
Old 09-22-2004, 04:22 AM
echrisconnor's Avatar
Just jumping in for final clarification since JW always speaks the truth. I have a '76 car without the oil bypass modification. I switched from the slotted style caps to the hex styles without any other modifications, since this mother of all screwdrivers system was a pain in the a$$. Is this a problem? Do I need to switch springs too or put spacer washers in there? Just concerned since I'll be firing up after my top end rebuild next week.
'76 911 Carrera 3.0
Old 09-22-2004, 07:47 AM
mike95125's Avatar
I just tried to by the older style holed pistons and slotted caps for my '74 2.7l from Pelican and was sent the hex caps, two springs of equal length (the correct springs), and holeless pistons. I called the Pelican Porsch parts guy and he informed me that the piston with the hole in it has been superceeded by the one with out and that the hex caps are an acceptable upgrade to the slotted type. I believe that the catalog here even says that it is an upgrade to swtich to the hex caps. If you have the oil by pass mod then you need to use the different length springs with the spacer/rod in the middle of one of them according to the catalog and Waynes book. This is all of the info that I just found out. If I am off, or have gotten bad info please let me know.
HTH
-Mike
-74 BMW R90
Old 09-22-2004, 09:43 AM
John
I respect your opinion but how much do the hex head and slotted caps differ in depth? I would consider them interchangeable even if they differed by a few mm, with the length of the spring its only going to alter the oil pressure a few percent
Neven
Old 09-22-2004, 10:19 AM
oneblueyedog's Avatar
Pipe wrench worked for me on the originals. Taped them with masking tape. Just a few tiny nicks.
78SC coupe, Silver Metallic
Old 09-28-2004, 07:24 PM
