Help needed installing piston wire locks
There must be a trick to installing the wire locks on the JE pistons. The instructions say you thread the wire locks in but I just can't see how that will work. I've installed Mahle pistons before and had no problems.
Help and advise appreciated. Felmir |
I saw some very good suggestions in this past post on the subject:
http://forums.pelicanparts.com/showthread.php?s=&threadid=171718&highlight=piston +pin+clips |
Thanks for forwarding the thread! I was searching on the wrong key words..."wire locks". I figured this issue had to be raised before on this board.
| All times are GMT -8. The time now is 05:26 PM. |
