-   -   How do I spin the crankshaft? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/183762-how-do-i-spin-crankshaft.html)
Alan Cottrill 09-22-2004 01:43 PM
I'm glad this worked out!
now...are you sure you put the seals on the oil pump?:)
sorry couldn't resist. I forgot to put them in the first time I assembled my case. I remembered the second time I assembled my case, but that time I pulled one of the perimiter studs. the third time I assembled my case I got it all right.
Rot 911 09-22-2004 02:56 PM
Put plastic wrap over the openings in the piston case to keep the wrist pin clips from flying off and dropping down into the engine!!!!!
cassidyp 09-23-2004 04:53 AM
Didn't get as far as I would have liked. Something about having 3 young kids... I did put the rings on 3 of the pistons and that wan't too bad. I found that the tool I purchased was sort of clumsy so I just used my hands. I have Wayne's book and can see why the plastic wrap is so important.
I did read that I should start at the transmission side and work backwards when installing the pistons on the arms. Also install one circlip while on the workbench right?
Rot 911 09-23-2004 08:44 AM
Yes one circlip on the bench and the other after the piston is installed.
