cassidyp's Avatar
5 of 6 pistons & cylinders installed
Last night I got 5 of the 6 installed. 1 left to go and felt I was too tired to try the 6th. What a bear. Wayne's book says 3 or 4 hands and that may be an understatement! Any good advice on getting things lined up to put the pin through the rod? I had to turn the engine so that I was putting the assembly up onto the rod from the bottom. Between putting these on and the darn circlips I was at my wits end, so I decided to let it wait until I am fresh tonight.
72 911 Targa VTK Member 110245
71 911 Targa
68 911 non sunroof Coupe
Gruppe B # 3911
http://www.pelicanparts.com/gallery/cassidyp
Old 09-30-2004, 04:31 AM
After doing the circlips a couple of times, I finally found the trick to them. As for getting the rods through, it's just a feeling you develop. I did mine by myself (mostly) and eventually got the feel for it. Rubber mallet came in handy and had to ask my wife to tap on it a couple of times while I positioned it with both hands. Doesn't take a lot of force but just enough sometimes to help you line it up.
As for the circlips, if you put the open end down and into the slot, you can push the top in enough that it holds. Then, just use a small screwdriver to push them in. It's a little hard on your thumb getting them started but once you get the hang of it, it's not to bad.
Of course, this only applies to stock. If you have the aftermarket stuff, I hear they are a pain.
And congrats on learning the biggest rule of rebuild. When your tired, walk away. It took me a while to learn that trick.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 09-30-2004, 08:26 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
I put the cylinders on by myself, but then again, i installed the pistons and rings on the rods first, then the cylinders afterwards. I just used pelican's ring compressor kit designed for air cooled motors.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 09-30-2004, 09:36 AM
David's Avatar
This raises a question I've had since first reading Wayne's book. Does anyone actually put 574 on the base gaskets?
Old 09-30-2004, 10:53 AM
I put dow 730 around the "skirt" of the cylinders just below where the copper shims go. just a thin ring of it does great.
Old 09-30-2004, 04:23 PM
