Are there two sizes for circlips?
Hi. Me again. Just received my order for circlips. I checked and they are 22mm inside diameter. When installing them I have an overlap? Should I be using a different size? I Am trying to find one of the ones from my removal process to check but would appreciate any advice. 2.4 with original pistons and cylinders.
Cassidy,
I had the same experience - I purchased OEM Porsche clips from Pelican and there was quite a bit of overlap. I used a good pair of cutters and trimmed the clips down so that they fit in the piston like the old ones did. Wear good safety glasses when you do the cutting! I did re-check the part numbers after the fact and everything was kosher. |
Dave,
Thanks for the quick response/ suggestion. Was your experience with overlap of the circlip on a 2.4 liter engine rebuild? I wish I could find one of the ones I removed and measure it. |
The piston wrist pins went from 22mm to 23mm with the '84 Carrera and (I believe) with the 3.3 Turbo. Maybe the 23mm clips overlap if you use them in a 22m wrist pin hole?
-Chris |
Chris, These are to fit in my 2.4 T engine. It seems that somewhere I read that 18mm size is correct. This looks about right. The ones I received are 22mm
| All times are GMT -8. The time now is 05:25 AM. |
