Need a rebuilt long-block...
I don't think I'm up for a complete engine rebuild... Does anyone sell a rebuilt long block? Or maybe someone out there knows a good rebuilder I can send my long block to...?
Story: My flood damaged 24,000 mile, 3.6 motor runs well in my ’93 C2, but I found some metal shavings and a small 4x6mm chunk of aluminum that looks like the bottom edge of a cylinder wall in the oil after hearing clunking noise. Before that, the engine ran well though 3 oil changes where I warmed the engine for 5-minutes and revved her a bit – just trying to flush out any water. The oil came out fresh and clean until "the noise." Compression test while cold, no sparkplugs in, and a fresh battery charge, is around 200 PSI per cylinder, except for one that is 165. Oil pressure is good. Engine runs fine. However, I have little confidence in it at this point… Thus, I need to crack her open to see what is damaged. Or, I buy a rebuilt long block which is more on my skill level. I could drop in a complete used engine, or a long block, however, I again have that unknown issue. Any thoughts?? |
Not sure what you mean by a long block. I'm not sure the term quite applies to a Porsche air cooled engine where the engine comes apart like a bunch of "Lego" pieces. The cylinders are not part of the case and are held to the case by studs that go through the cam towers/heads. If you are going have to replace pistons and cylinders you are not that far from splitting the case and checking for damage there. Jim
Try not, Do or Do not
SUPERTEC PERFORMANCE will rebuild your long block at a fair price for top quality work. We offer a 2 year unlimited mile warranty.
![]() OR THE WHOLE BALL OF WAX . This one is a 2.7 RS spec for a 914/6 GT
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 10-08-2004 at 01:43 PM.. |
That is just SOOO pretty. BTW, nice talking to you yesterday, Henry. You gave me a lot to think about.
Bill G. '68 911 Ossi Blue coupe Last edited by 911SCfanatic; 10-08-2004 at 11:37 AM.. |
That is one sweet looking engine. Expect my call shortly!
Information Overloader
So what do you mean by 'fair price'...
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
