-   -   Stubborn Trany Drain Plug (http://forums.pelicanparts.com/911-engine-rebuilding-forum/186348-stubborn-trany-drain-plug.html)
ausgezeichnet 10-09-2004 01:18 PM
Trying to change my transmission oil today. Started with the fill plug first. Finally managed to get it out (It was a bear!). However the drain plug just won't come out. I've hit it with PB blaster several times and almost popped a vain pulling on it but can't get it to budge. At this point I am going to keep hitting with PB blaster over the next several days. Any other sugesstions? Thanks.
ausgezeichnet 10-09-2004 02:04 PM
Got it out! A liitle heat from a hallogen lamp did the trick.
Nitrometano 10-11-2004 06:24 PM
Put some penetrating oil too.
afterburn 549 10-13-2004 11:41 AM
think torch, thinktorch,, think torch............................................. .................................................. .................................................. .................................................. .............
