Identify this fuel filter??
Can anyone ID this filter, and know where I could find another?
Someone told me it's from a mechanical injection 911, but I've had no luck finding the right replacement. I've seen a similar one but it had no port on the bottom. It's off my vintage race 914, and I'm about to go to a Canton, but maybe I can save a few $$ ...
Thanks,
Gavin
Old 10-11-2004, 04:13 PM
magic930's Avatar
Looks like it comes apart? Maybe you only need to replace the filter element.
Old 10-11-2004, 07:21 PM
Looks like a 911 MFI filter housing/console (PN 901.110.232.00 available new and complete for $651.80!) although the fittings and plugs are changed from the MFI configuration. It appears you can change out the filter element/housing (PN 901.110.909.00) for a mere $65.10. Jim
Old 10-11-2004, 07:46 PM
I think you nailed it Jim! Thanks.
Sorry I forgot to mention the filter canister unscrews from the base, and yes the porting has been altered - no return line.
Damned expensive filter, but at least I won't have to re-plumb my
fuel lines. Great help!
Gavin
Old 10-12-2004, 04:31 AM
