73 Engine Pics Required
Hi
I'm just finishing up my 73E MFI Engine and was wondering
someone had some pictures of a std 73MFI so I could work out the routing of
1/ The engine harness
2/ Vacuum advance/retard hose
3/ Spark plug wires
etc
The engines been apart for a long time.
If you wish could you email them to me at neven@mwk.co.nz
TIA
Neven
Old 10-15-2004, 02:22 PM
Warren Hall Student
Bobboloo's Avatar
I'm not at home so I can't post a photo.
1/ The engine should have two harnesses for 73'. 1) ignition harness that hooks up to the CDI box and ... 2) 14 pin connector harness. Pelican has a diagram for a 71' that is from the factory manual. You can down load it from the site.
2/ The vacuum retard lines go to each throttle body brass tube at cylinders 1 and 4 and are connected by a T that goes to the distributor retard/advance tube.
3/ 1-6-2-4-3-5? I think? It should be written on the gold label on the rear crossmember.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 10-17-2004, 09:20 PM
Bobby
Thanks, I've got the generalities, I more need the specific details, ie does this go under or over that etc
Neven
Old 10-17-2004, 10:20 PM
