-   -   72 MFI pump fuel inlet size? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/187790-72-mfi-pump-fuel-inlet-size.html)
bob911rss 10-18-2004 11:11 AM
Hi, :confused:
Does anyone know the size of the hollow bolts that go through the fuel inlet banjo fittings on the mfi pump?
I have two mfi pumps one manufactired in February and the other in September, they are both 015 pumps for the 1972 911T. The problem is the latter pump uses a larger size hollow bolt. I don't want to change the threading on the earlier pump so I thought I would try to locate the proper size hollow bolt but I cannot find any references to the size.
If anyone has a set of hollow bolts and banjos I am interested in buying them.
Thanks, Bob SmileWavy
Henry Schmidt 10-19-2004 01:14 PM
http://forums.pelicanparts.com/uploa...1098220347.jpg
Supertec has these and almost any other MFI part you might want.
