SnakeDoc's Avatar
Porsche Crest backfire on carbureted '72
I've got a '72 911T with Webers.
Had really gunked up carbs, that's been fixed by a local good shop.
It continues to backfire on rapid deceleration, after coming off a heavy acceleration period. These backfires are like gunshots, not the pleasant burble of engine breaking, at all.
I'm a newbie. Is this normal? I think not. If not, though, what aside from dirty carbs could explain? It's supposed to have been tuned up before I got it, and is accerating noticably better since the carb rebuild.
Timing is on my mind, and I need to buy a strobe light. Feeler guages for the points, I do have.
Thanks for any help.
Tom in Memphis
'72 side oiler Targa:
A project, a passion, a Porsche!
Old 10-25-2004, 11:51 AM
klaucke's Avatar
I would say timing. Keep in mind that even if you set your timing at idle with the right points gap, it could be your advance that is screwed up. That and you could be running a little lean, although I think a little backfiring on decel is acceptable and "normal" depending on application (although I realize yours is more serious).
Old 10-25-2004, 12:15 PM
I would rather be driving
jpnovak's Avatar
Could also(and more likely) be running way too rich and air leaks in the exhaust system. Usually between the head and Heat Exchangers.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 10-25-2004, 12:25 PM
Nitrometano's Avatar
Yeah anoter Porsche with nitro!!!
jeje
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 10-26-2004, 01:06 AM
Last Century User
Porsche Crest Backfire
I had the same problem with my 72e, MFI, boy the backfires were LOUD. It was a leaking muffler, when you back off, air (oxy) is sucked into the system, when you get back on it the engiens run so rich, so bang! So I woud ck the timing and then exhaust leaks.
Old 10-26-2004, 09:47 AM
SnakeDoc's Avatar
Leaking muffler, huh?
That's the first thing Pat Williams suggested, muffler hole, when I complained about it before the carb cleanout. Guess I need to have a look for holes. Would lousy heat exchangers qualify for that effect, you think?
Old 10-26-2004, 02:21 PM
Banned
snowman's Avatar
Back fires are from one of two places. one is out the exhaust the other is out the carbs, less likely. Which do you really have??
I would suspect you actually have backfires out the exhaust, much much more common. THis is caused by two things. One is an air leak into the exhaust. Without an air leak you cannot have back fires in the exhaust. You MUST have an approx 12:1 A/F ratio for an explosion. Without the air you CANNOT have an explosion. So this is the first place I would check. Leaking gaskets, holes in mufflers, pipes, heat exchangers. The second condition necessary for backfires in the exhaust is excess gas, ie unburnt fuel. Leaking floats, bad valves, whatever may be responsible. LEaking valves can be rulled out by a leakdown test. Carbs are the last thing to check.
Old 10-26-2004, 09:50 PM
