What oil pump to use on the 67S rebuild?
The original one looks fair, there's some scratch marks on the impellers (is this bad?) and a little bit of play when turning it (i.e. the impellers will click a bit as it rotates).
What I'd really like to know though, is there a better pump that requires no case modifications, and if so, how do I identify these as I'll probably be looking for a used one. Thanks, Bill
Current: 1975 911S --Chocolate brown Past: 1967 911S --Bahama Yellow 1990 C2 Targa --Silver 1973 914 2.0 --Delphi Green |
up-fixing der car(ma)
Bill, go ahead and try to find a 76-83 style, usually referred to as the SC pump, or get the later Carrera 3.2 pump. Both fit right in, but with the carrera pump you will have to get a new sump plate with no drain plug... Do the oil bypass modification while you're at it...
Best! Scott
Scott Kinder kindersport @ gmail.com |
I use the carrera pump in my 2 race engines, dont forget the oil bypass mod.
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
