-   -   911 main bearings (http://forums.pelicanparts.com/911-engine-rebuilding-forum/190733-911-main-bearings.html)
bkb500 11-04-2004 12:57 PM
911 main bearings
I have a '78 3.0 case that needs align-bored. The crank is stnd., however the case side will most likely be .25mm oversize after the bore. Where can I get bearings, and at what cost?
Henry Schmidt 11-04-2004 04:50 PM
Dealer and they are not cheap.
Wholesale is about $475.00
Good luck
ChrisBennet 11-04-2004 04:54 PM
What's cost to resize the case back to standard?
-Chris
Henry Schmidt 11-05-2004 07:15 AM
About $450 plus std bearings. $225 ?
ChrisBennet 11-05-2004 09:50 AM
Sounds to me that he'd be save money by having the case resized instead of line bored.
-Chris
bkb500 11-05-2004 11:17 AM
Thanks to all that have replied so far. I since learned as Henry Schmidt suggested, that the dealer can order the bearings. Get ready for this!, $1,239.00. There's a chance however, that I can get the machine shop to pay for them; as there is evidence of the case been mis-matched.
As far as shaving the case halves; I'd be nervous about all the other ramifications like intermediate shaft bosses, piston clearance, and I'm not sure what else.
Henry Schmidt 11-05-2004 11:45 AM
The machine shops that resize these cases take all of your concerns into account. [Remmeber we're talking about a few thou not a 1/4 inch.]
We do and I'm certain the Competition Engineering and Ollies do to.
If you have a favorate machine shop that specializes in Porsche machine work, just ask.
914/6 11-07-2004 07:38 AM
Did they have #8 or nose bearing in the csae when they torqued it together to check it ?
bkb500 11-08-2004 01:50 PM
Thanks for your advice Henry; the case is been hand delivered to Ollie's on thurs.
