chain ramp removal
Prematurnely put the RS chain ramp on before slipping the chain around it. Can i pry the tabs open to allow for removal and then re-install the chain ramp after looping the chain around? Or should I simply pry it off and order another one to be safe?
get under the ramp with a curved crowfoot next to the pin that the clips are holding to, and gently pop it off. new ramps are more flexible than the old ones, so the clips probably won't break off.
John,
Thanks again for your expertise and willingness to share it. I got it off and the housing on correctly. Hope things are working out for you and your battle with the city. If you have to re-locate think about here in Central Pennsylvania! Thanks again. PC |
| All times are GMT -8. The time now is 07:16 AM. |
