How do I get large oil line to motor nut (down by the return and pressure pumps) off!
If I try to turn the large nut the entire line moves but not the nut. (Cannot find anything in either of Wayne's book on this) Motor is a 69 E.
Help, Thanks! |
There's an adapter that's between the oil line fitting and the engine case. You'll need to hold it with a thin 32mm wrench as you lossen the oil line.
| All times are GMT -8. The time now is 12:38 PM. |
