-   -   How to C/R ratio?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/191731-how-c-r-ratio.html)
afterburn 549 11-10-2004 05:29 PM
How to C/R ratio??
Will this work...put a "o" ring on the fire ring groove -T.D.C. it. Put plug hole up and fi it (cout the cc) Put the piston at B.D.C. fill it the rest of the way up.....will this work??
thanx...........I am just looking for a simpler way to do c/rs
Bill Verburg 11-10-2004 07:46 PM
Doesn't get much simplier than the procedure illustrated here
911pcars 11-10-2004 07:52 PM
ATF also works.
Sherwood
afterburn 549 11-12-2004 04:46 PM
Thats the pt..would ths be more simpler??.......One less thing to do....less room for error???...
ChrisBennet 11-12-2004 05:02 PM
It looks a lot easier than it is IMO. I must admit, I have a difficult time getting consistant results. It takes very little CC error to make a large change in compressio ratio.
-Chris
afterburn 549 11-12-2004 05:13 PM
Yea I know Criss....Just lookin for a simpletons way...there has to be a simpler way.......It would seem if all the heads were cc out to the exact then the rest would be more ezer.........http://www.pelicanparts.com/support/smileys/pirate.gif
