Late 80's cams in an early 3.0?
When rebuilding my motor can I use a pair of cams reground on late 80's cores in a 3.0 Euro carrera motor? If so what other parts relating to the cams will I have to change over?
Robert
Old 11-11-2004, 09:35 PM
ChrisBennet's Avatar
You'll need the bolts and big "washers" for the end.
Pelican parts #'s J-082-072-01 (bolt) and H-105-163-00 (washer).
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 11-12-2004, 05:21 AM
Bill Verburg's Avatar
ALL SC & Carrera &Carrera 3.0 cams are the same grind. The just used a 6&deg range of different timing specs.
Bill Verburg
Old 11-12-2004, 12:19 PM
I think he said that they were "cams reground on late 80's cores" i.e. not the stock cam grind.
-Chris
'07 BMW 328i Coupe
Old 11-12-2004, 06:36 PM
Yup Chris, more radical cams for a high compression motor with carbs. From your post I understand that I just need to get the two bolts and washers to replace the old nuts and washers.
Robert
Old 11-12-2004, 08:33 PM
Robert
Yes, that is my understanding at least. I've built motors with both kinds of cams but never "converted" between them.
-Chris
'07 BMW 328i Coupe
Old 11-12-2004, 08:40 PM
Noah
The cams I have in mind are GE80's but have been ground on late 80's cores.
Robert
Old 11-15-2004, 12:04 AM
camgrinder's Avatar
The late cores will work by changing the attaching hardware.
I have 3.0 billets with the nut style snout that will accept any grind.
John Dougherty
Dougherty Racing Cams
Old 11-15-2004, 09:25 AM
Super Moderator
cstreit's Avatar
I'm assuming we're not worrying about piston clearences, etc.. for purposes of your question?
Chris
2008 Yamaha R6
2001 GT3 Cup - "Pepin"
1999 Spec Miata
1996 993 RS Replica
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-15-2004, 10:50 AM
